37x13.50R17 or 38x14.50R16
Old Feb 11, 2007 | 05:47 PM
f150mudder01's Avatar
ok will either of these fit w/ a 6" lift and 2" or 3" body lift? the 38's are actually cheaper cuz theyre made for 16" rims.
Old Feb 11, 2007 | 05:53 PM
fordfanatic32's Avatar
What Kind Of Truck Is It?
Old Feb 11, 2007 | 05:57 PM
Sorry I Just Took A Look At Your Pics. Dumb Question. You'll Definitely Have Bad Rubbing With The 38's. Also Have Rubbing With The 37's But Much Less. You Will Need The 3 Inch Body Lift To Have Any Chance Of Fitting Either Of Those Tires Though.
Old Feb 11, 2007 | 07:51 PM
wandell's Avatar
If you have a 4x4, you could fit either with 9 inches of lift, but it's tight.
Old Feb 12, 2007 | 05:32 AM
bigtruck311's Avatar
with a 6" susp. and a 3" body, both of those tires will fit with some cranking the torsion bars up, but those tire will fit just fine and a little trimming and cut the nub off the lower control arm and they wont rub, good luck
