backspacing & dish comparison
Old 02-06-2007, 06:27 PM
nooq's Avatar
quick question...would a 20x10 wheel with -25MM offset and 4.52" of backspace have a larger lip (dish) than a 20x9 wheel with +12MM offset and 5.47" of backspace? or will they both have the same amount of dish, just the 20x10 is 1 inch larger in width than the 20x9? thanks for any help guys. -Ryan
Old 02-06-2007, 06:32 PM
Mange's Avatar
The 10" wheel is going to have more lip. It's wider, and has less backspacing. Depending on the design of the wheel/thickness of the spokes, you could be talking up to a couple inches more dish.
Old 02-06-2007, 07:10 PM
nooq's Avatar
they are these wheels, http://www.tiresdelivered.com/prodde...53-25&cat=1117
what do you think...bigger dish with the 10 width less backspacing?
Old 02-06-2007, 07:43 PM
wandell's Avatar
You have to be concerned about fitment also. On the new F-150's a 10 inch wide wheel with 4.52 inches of backspacing is gonna stick out really far.
Old 02-06-2007, 11:48 PM
nooq's Avatar
these wheels will be going on my 2wd f150. It has a 6inch suspension lift and 3inch body lift. iam going with 35 inch tires. do i still need to be concerned wandell?
Old 02-07-2007, 08:07 AM
wandell's Avatar
I think 35's with those 10 inch wide wheels will be a tight fit.
Quick Reply: backspacing & dish comparison
