305/65-18 vs. 285/65 –18
Old Jan 5, 2007 | 11:41 AM
Rochester's Avatar
I will be putting one of these tires on my stock FX4 rims in the coming month or so. They will be the BFG T/A KO tires. My question is which one? I am mainly concerned with the ride stiffness. Will the added profile height of the 305 cancel out the negative effects of the extra width? These are both E load range tires. I am coming from the 275/65-18 Goodyear ATS, which I believe are only a C load range tire.
Old Jan 5, 2007 | 01:17 PM
Jordan not Mike's Avatar
I think you are on the right track...a taller sidewall generally provides a little extra ride comfort.
This is one reason why I run 60-series performance tires on my Expy, and am not interested in huge wheels with skinny sidewalls.
Old Jan 5, 2007 | 01:46 PM
smitty'slariat's Avatar
I got the 305's and they ride just fine, i drive on the interstate 30 min to work each day both ways , bigger is better, get the 305's. I have only lost 1.2 miles per gallon, and it rides a little stifferbut not enough to hardley notice, and its a truck not a luxury car.
Old Jan 5, 2007 | 04:00 PM
mewaschuk's Avatar
Registered User
I thought they only came 265 or 285 in the 18", no 275? I will be getting the 285/18s on Tuesday with the 2.5 AS. I'll keep you posted.
Old Jan 6, 2007 | 10:35 AM
DCinMI's Avatar
Do you have any mods up front to help with lift? It would seem to be a tight squeeze (diameter-wise) if you go with that 305/65/18. I'm not 100% sure, but just a guess.
I've read about guys getting the 285's on with no problems. Just not sure about the 305's.
Old Jan 7, 2007 | 10:30 PM
Rochester's Avatar
The Goodyear’s I currently have are 275. The BFG's in an 18” rim come in widths of 265,285,305 & 325. Yes I have a 2" spacer up front. I am not concerned about the fit of either I was asking opinions on the ride difference. Generally speaking a wider tire gives a rasher ride due to the larger contact patch. Conversely the taller sidewall gives more cushion. Thanks for the help.
Old Jan 8, 2007 | 02:20 AM
FX4life's Avatar
Id say the 305's, thats what i plan on going with. Ive seen a couple of pics of them on stock 18's and they look great. The 285's look good, but are a little small i think.
Old Jan 8, 2007 | 03:11 PM
Copenhagen848's Avatar
I'm pretty sure you'll need a leveling kit with the 305's. The 305's get my vote.
Old Jan 8, 2007 | 06:21 PM
DCinMI's Avatar
I guess I kind of missed that in your first post. Sorry.
I do know that all else being equal, more sidewall = more cushion. Your question regarding the dynamics of tire width in conjunction with taller sidewall is intriguing.
I'd say just go with the 305's and any little bit of stiffness in your ride will be offset by how sweet they look.
And show us some pictures when you're done!
Old Jan 9, 2007 | 01:02 PM
Could not said it better myself. Nicely put
