Trooks2001?????
Trooks2001?????
What backspacing do you have on your truck, it has a mean stance? Did you have to do any trimming? Would they have fit without the Spacer in front?
thanks for the info
thanks for the info
we have the same wheels but the main contributing factor to the stance..which i think is what you like are tires...which are 15.5 wide
and yes 36's will fit with some trimming.......as mine did.....but i personally had to add the 3in body lift to totally eliminate it... I think his experience has been different though
thanks for the info
thanks for the info
I trimmed the front valence and havent rubbed since. W/o the level kit I think I would have a good bit of rubbin.
Originally Posted by quickie4x4
trooks....how long have you been running the level kit with the lift? noticed anything wearing prematurely? also, can you run the level kit with the coilovers? thanks!
