Abs light after brake work
Old Nov 29, 2006 | 05:24 PM
Unit73's Avatar
Just replaced front brake hoses and rear wheel cylinders on my 97 f150. After bleeding the system muliple times, the abs light is lit when it never was before. Any suggestions? I know there is a sensor that usually goes bad, but could the brake work have caused it to fail? Any help would be appreciated. Thanks!
Steve
Old Nov 30, 2006 | 09:53 AM
Colorado Osprey's Avatar
Pull codes...it will tell you what is wrong
Old Dec 1, 2006 | 07:17 PM
Unit73's Avatar
Light went out after a 10 minute drive and hasn't come back. The brakes feel great so I really don't think there's any air left in the lines. I'll try and get the code if it comes back. Thanks!
Old Dec 1, 2006 | 07:57 PM
keith97xlt's Avatar
i replaced the steel line all the way from master to rear brake hose. i had the same problem ABS light came on. had to bleed 3 times all around before it went out finally.
