ABS: How do I know I have it?
Old Nov 29, 2006 | 01:22 AM
GrnXnham's Avatar
I have a 98 XLT 4X4 Supercab with the 5.4L that I purchased used.
I know the XLT comes with rear ABS standard but 4 wheel ABS was an option for that year. Is there any way to find out if I only have the rear ABS or if I have 4 wheel ABS?
When braking on the ice, I can feel the ABS kicking in a little bit. When I 1st start up the truck the ABS light comes on momentarily.
Just curious.
Old Nov 29, 2006 | 07:53 AM
projectSHO89's Avatar
Inspect your front wheel spindles for any wiring.
If found, it's 4WABS. If no wiring, it's RABS.
Steve
Old Nov 29, 2006 | 08:53 AM
Colorado Osprey's Avatar
The wire that was referred to will be attached to your soft(flexible) brake line. If you see 2 lines (brake line and ABS line) attached together running under the fender well and the brake area, it has 4 wheel ABS.
The outboard CV will also have an exciter ring to trigger the ABS sensor.
Since your have an XLT more than likely you have 4 wheel ABS. Mostly XL's were the ones ordered without 4 wheel ABS. Obviously you could have had somebody order your truck, but most likely it was a dealer package order.
Old Nov 29, 2006 | 10:39 PM
GrnXnham's Avatar
Okay, there is a 2nd set of wires zip-tied to the brake line inside the wheel well. So it looks like I have 4wheel ABS. Thanks for the help.
