BFG TA/KO 305/65/r18 on stock or new wheels?
Originally Posted by FX4_shadow
Thanks for the help.
A leveling kit evens out the front end with the back end (the stock setup is higher in the back end) . i have the daystar kit (http://www.daystarweb.com/ItemForm.a...9-8512f994e742) which runs about $130. there's other manufacturers too. I had my local mechanic do the work, but you could probalby do it yourself if your mechanically inclined. you'd probably need to have this kit if you want to go with bigger tires, depending on the size you want.
No rubbing whatsoever. The ride seems a bit stiffer, but not bad for a truck. Running them at 50psi right now, but may lower that. i think max. is 65. i purchased the mud flaps from ford a couple years ago and just finally had them installed when the tires were put on (you have to remove tires to install). as for the noise level, i haven't noticed a difference. of course it's cold here and the window are up, plus the flowmaster probably downs out some of that noise anyway.
great setup Dog'em, now i'm wondering if i should have gone with the 2.5" leveling and 1.5" leaf in the back. with the 34.5" tires it looks pretty jecked up! any rubbing/performance issues with that setup? notice any difference with the K&N air filter?
The K&N, nothing you can feel in the seat of your pants, I just have used their products in my past three trucks and like the concept of better airflow.
