brake stroke doesn't seem right
Old Nov 11, 2006 | 08:07 AM
306stang's Avatar
i know that now days you shouldn't have to pump the brakes to really get them working. however i've noticed the past week that if i get on the brakes, doesn't matter if it's light or hard, the pedal stroke is longer than if i pumped it once. if i don't pump it the pedal goes down probably around 2-4" before it really grabs. if i do pump it the brakes grab almost instantly and the pedal stroke is maybe an inch.
fluid is fine and the pads seem like they still have a good bit of life in them.
anyone else ever noticed or experienced this??
Old Nov 11, 2006 | 01:08 PM
306stang's Avatar
hello? anyone home
Old Nov 13, 2006 | 05:44 PM
GIJoeCam's Avatar
Odds are you have an air bubble in the line. The first pump compresses it, the second pump gets better pressure. Time for a brake bleed.
-Joe
Old Nov 13, 2006 | 08:39 PM
DIYMechanic's Avatar
-Joe
X2 Sounds right to me. Bleed the brakes out and I bet your problem disappears.--DIY
Old Nov 15, 2006 | 06:29 PM
306stang's Avatar
cool thanks guys
hopefully try it this weekend when i get some time.
Old Nov 17, 2006 | 02:44 PM
keith97xlt's Avatar
[QUOTE=306stang]cool thanks guys
hopefully try it this weekend when i get some time.[/QUOT\
bleed them good ,go around twice.if you still have no luck id suspect master cylinder, booster
