bleeding brakes
bleeding brakes
this is my first f150 truck, i had to replace all the brake lines do to corosion, when i went to bleed the lines. I am stumped. the front do not have bleeder nipples. the back were no problem but the front i can not find . it is a 1991 xl v8 w fuel injection,. I think, well does anyone have any info i can use. thanks
look closer, they are there somewhere but if you absolutely can't find the bleeders, here is an old standby trick that'll work as long as the calipers aren't full of air, loosen the brake line and listen for air as a buddy pumps when there is no air tighten them good with new copper washers.
p.s. if they are new calipers full of air take them off again and fill them with brake fluid on the workbench(it will make life easier when bleeding)
