adapter problem
Old Oct 22, 2006 | 07:01 PM
F150CKICK's Avatar
adapter problem
just installed 2" adapters on the truck. now there is a vibration and at 40mph it wants to rip the wheel out of my hand. i have torqued everything down but the problem is still there. has anyone had this problem before?
Old Oct 22, 2006 | 08:24 PM
wandell's Avatar
Do you mean wheel bolt pattern adaptors? Sounds like that is the problem. One or more of them must have a defect.
Old Dec 15, 2008 | 10:49 PM
norm_52's Avatar
i have the same issue with mine
Old Dec 15, 2008 | 10:55 PM
4.2trimble's Avatar
Id take all the wheels off and check the spacer. I put 2" Spacers on mine and was 1 lug away from loosing the front passanger tire. then i almost lost the front driver tire.
The lugs keep backing out. So i used lock tite on them and problem has been solved for the mean time.
What year and model do you have?
Old Dec 15, 2008 | 11:00 PM
norm_52's Avatar
03 fx4 with the washer style lugs that the spacers say i shouldnt use, any idea why?
Old Dec 15, 2008 | 11:01 PM
norm_52's Avatar
i will re tighten everything tomorrow to see if it helps. but like i said the spacers say no asher style lugs, i dont know why that is.
Old Dec 15, 2008 | 11:32 PM
4.2trimble's Avatar
Mine said the same thing.
i bought all new lug nuts for the spacer and wheel. Then i put blue locktight on them.
They dont seem to be moving now. If they come loose now i wont be putting them back on.
You can see inside the spacer that conical lug nuts are needed but the wheel still needs washer type nuts.
