Gears
I went with 4.1 for that same size wheel/tire combo, and I also have intake, exhaust, and tuning. It was definitely a great improvement over the stock 3.55 I had.
I have a 5.4 though... and even I partially wish I had gotten 4.56 gears. Especially if you have stock 3.73s, I would suggest going to 4.56s to make sure it is really worth the cost.
The downside is the engine will run at higher RPMS and you will likely lose some MPG. If you REALLY want performance, go 4.56, fi you want a solid blend of economy and performance, go with 4.1s.
Originally Posted by Green Ford
Well my truck is a daily driver. would 4.10 gears be good for that . Just want to get a little extra preformance . And what brand should i go with . one more thing" Lumadar where did u get your headlight . thank u : confused:
As for the headlights, sorry to say it but they are actually stock and my friend photoshopped the amber out for that pic. ALTHOUGH, that same friend also claims he saw a brand new F150 with headlights that look totally OEM with clear housing. He waited for the owner to come but he never did
So ford makes some gears cool . As for the light would have never know .That they where not real , Looks good anyway. but i did see 2 set of clear heardlight on ebay out of all those other projection set . They did look like the headlight in your pic .
Also I got a set of 4.10s on the way...I went with Ford Racing...
