99 f150 rear brakes sticking
check the tensioner on the ebrake. It should be pretty tight, people that dont use it have more problems with it. B.c the cable stretches over time, and the ebrake gets lazy and start rubbing. And on a drum brake set up, the same pads are utilized for the ebrake i believe. try making sure the cable is tight, should be just under the gas tank filler neck by the frame rail.
btw i use mine everytime i park my truck, both as an insurance to not have it roll away if trans give out, also to prevent damage to the teeth on the "park" gear. those wear out over time, especially if you park on a hill, and let it roll back when its in park.
-Patrick
-Patrick
