Rear Cab Light...
Rear Cab Light...
I don't know where this question fits, so I figured Id put it here since in a small way, it has to do with braking. What is the replacement part called for the rear lamp above the bed of the truck, on the cab? Mine is cracked and I need to replace it and the bulb, but I don't know what the technical term is. Sorry if this is in the wrong spot, thanks for the help.
Should be "third brake light assembly." Check out www.car-part.com to search junkyards. A quick local (OH) search turned up several for only $10.
Andy
Andy
