Tire/Wheel size help
I am looking at buying some BFG KO 285/65/20 and want to put them on a set of Liuid Metal Magma wheels. I do not know the backspacing or exact width. I measured and they are around 10" They currently have Nitto 305/55/20 tires and there is just too much air between the tire and wheel well. I mounted the wheels and tires on my truchk and they seem to extend outside my fenders about an inch further than the OEM wheels/tires do. Will the 285/65/20 fit....If not, is there a better choice? I have aqn '06 4x4 and just do not want to rub. Thanks.
I am not certain! But, I just went back to the BFG site and it is definately listed there. Here are the spec's on both tires.
LT285/55R20/D Rim Width --- 8 - 10 width on rim --- 11.7 on 9 overall diameter --- 32.5
LT285/65R20/E Rim Width --- 8 - 10 width on rim --- 11.5 on 8.5 overall diameter --- 34.7
Let me know what you think about these fitting under my '06 4x4 with a 2" leveling kit. I tried the wheels with 305/55/20 and there was too much room between the tires and wheel well for my liking. I really want to get a taller tire if I can withouot problems or rubbing. Let me know what you think. Thanks for your advise/help.
These look like they may be last years model...Liquid metal Magma. I went to the website and looked for this information. But, the wheels do not look exactl the same. They are roughly 10" wide and the backspacing is not known. Is there a way to measure that or find the specifications on a previous model wheel? Thanks!
I just put the new BFG K/O LT285/65/20 on my 05 4x4 scew with the AS 2.5 and Skyjacker 1.5 aal. The wheel I went with is a 20x9 with 6" backspace and I have no rubbing issues at all. Granted I've only had them mounted for a day but so far so good. Will post some pics or even start a gallery when I get my camera back from my son.
OK! I finally got the the answers. 20x10 wheels with 6.5" backspacing. Will this wheels work with larger (taller) tires and a leveling kit on my '06 4x4.
Wandell is the wheel too wide for the tire? If so, I would go wider. But, my main concern is filling the wheel well with tire......
Thanks for your help on this!
I would love to see pictures. Thanks. Since the wheels I am looking at are used I do not have the exact specifications on them. Do your tires fill your wheel well?
6.5" backspace with a 10" wheel might be a little much, not sure.
