bolt pattern
Old Oct 3, 2006 | 07:13 PM
projektlift150's Avatar
bolt pattern
hey i was woundering what the bolt pattern is for an 04 f150 4x4. I am looking to get aftermarket wheels and tires but wasnt sure what the pattern is. Plus if i turn the torsion bars up will i be able to fit 33's on aftermarket wheels or will i have some trimming to be done..
thanks
Old Oct 3, 2006 | 07:44 PM
BalogUK's Avatar
is it a new body style or old body style? new body is 6x135 bolt pattern and you can fit 33's without any suspension modifications
Old Oct 3, 2006 | 07:48 PM
so 6x135 would be equal to what, 6x5.5 or diferent?
Old Oct 3, 2006 | 07:58 PM
BalogUK's Avatar
nope a 6x135 is a 6x135... thats what you need.
Old Oct 3, 2006 | 08:36 PM
so if i go with 33" mickey thompsons on 17" mickey thompson classics i can fit without altering suspension and rubbing... sry guys im new to this and i just want to make sure i hitall my ?'s before purchasing. thanks for all the help
Old Oct 3, 2006 | 09:46 PM
BalogUK's Avatar
well- you need to test fit the 17's alot of 17" rims will NOT clear the brake calipers on the new F150's so be sure to verify the fit before you drop a chunk of cash but assuming you're good there- yes, you can fit the 33" mickey T's without any suspension changes (if its a new body style f150...)
Old Oct 4, 2006 | 07:51 AM
wandell's Avatar
I agree. Also, you don't have torsion bars, you have coilover shocks.
Old Oct 4, 2006 | 08:42 AM
05supercrew's Avatar
Im pretty sure that the 17'' on the aftermarket rims were good. Ford made the change mid 05 on the calipers.
Old Oct 4, 2006 | 08:48 AM
kingfish51's Avatar
That is true, but many of the 04's have gone thru the TSB which replaces the rotor and caliper with the later model. If that has been done, the limitation would be the same as the 05 up.
Old Oct 4, 2006 | 01:05 PM
ok well i was gunna go thru summit but seems i cant find that size wheel through them that i need, found the tire but not wheels. So once i find a dealer around here i can go through ill try n see if i canget it test fitted first, hopefully ill find sumwhere that i can.
One other ? with the coilovers, can u adjust them or not? My trucksgoing to the dealer tonight for a warrenty check up so ill find out if i can add the leveling kit and not void the warrenty i really hope so..lol if not ill deal with it
thanks for all the help guys.
Josh
Old Oct 4, 2006 | 01:11 PM
BalogUK's Avatar
Josh- is it the new body style F150?
Old Oct 4, 2006 | 03:41 PM
yea its the newer style f-150.
Old Oct 4, 2006 | 03:50 PM
BalogUK's Avatar
okay- there is nothing you can really do to moidfy the coilover- every dealer is different- some are cool with people modding their trucks, others wont touch em... if you put on a leveling kit, and 2k miles later your upper ball joints blow out, ford will most likely void the waranty on the suspension system because the leveling kit changes the angle of operability/increases the wear on the joints... understand?
Old Oct 4, 2006 | 04:08 PM
wandell's Avatar
Once again, I agree.
Old Oct 4, 2006 | 06:55 PM
ok guys thanks for your help. i guess ill find out at the dealer when i pick up my truck tomarow. thanks
