Question For Wandell, or anybody that has this..
Old Sep 25, 2006 | 09:54 PM
TonkaTruck33's Avatar
Question Question For Wandell, or anybody that has this..
Wandell i dont know if u remember but i asked you a couple weeks back about getting wheels also,(mb wheels Blitz 18x8.5) ive been thinking about it and i am gonna get the wheels afterall just wanted to know if u can give me some information about rubbing issues if i get a 3inch body lift would i be ok on full turns? or would i still have rubbing?? anything would help. thankz
just incase you forgot i have 325/65/18 nitto terra graps. on stock wheels now..
also what do u recomend (18x8.5 6-135 25mm) or (18x10 6-135 25mm)??
Old Sep 26, 2006 | 08:04 AM
wandell's Avatar
Where is the rubbing at now? If it's on the frame, the wider wheel will help that, but it may cause rubbing on the fenders. With a 35 inch tire you will probably be much better off with the body lift. Do they happen to have the backspacing listed for those wheels.
Old Sep 26, 2006 | 04:10 PM
it rubs on the frame on full turns and a LITTLE bit on the arm not that much. i just ordered the body lift from 4wheelparts 10min ago, so then u think i should go with the 18x10? no i cant find the back spacing im still looking though ill post it when i find the backspacing on these wheels.
Old Sep 26, 2006 | 04:17 PM
wandell's Avatar
Unless the 18x10's have a lot of backspacing they will probably cause rubbing on the fenders.
Old Sep 26, 2006 | 04:30 PM
even with the body lift??
Old Sep 26, 2006 | 04:44 PM
wandell's Avatar
It's hard to tell. I know that the Mickey Thompson 18x10 has 6 inches of backspacing and they appear to work fine. However most other 10 inch wide wheels seem to have a lot less backspacing and stick way outside the wheelwells.
Old Sep 26, 2006 | 04:48 PM
ill probly end up getting the 8.5 i have a buddy that has the same wheels and they look fine, but he has 33's and a leveling kit. BIG diffrence.. damn i dont know 10 or 8.5... haha
