Tire size
Tire size
I have stock OEM 18" rims and am looking at a 33 or 35" tire and not sure what will fit in the wheel well. I am addint a 2.5" autosprings leveling kit but i am not sure if i will have to shave anything out of the wheel well. Also will i need to change my gears when i take off my 265/60/18 and put on a 325/60/18 or 325/65/18? Thanks.
If you have a 4x4, you can fit a 35x12.50 by using the OEM wheels and a 2.5 inch leveling kit. The 325/65-18's (35x13.00) are a little too wide for the OEM 18x7.5 inch wide wheels so the center portion of the tire's tread will probably wear faster than normal. I'd try to find something narrower if you are gonna keep the OEM wheels forever. Keep in mind as a general rule on a 4x4 with a leveling kit, you can fit 35's with the OEM wheels or 33's with aftermarket wheels.
