wheel problem?? need your help!!
Old Sep 18, 2006 | 04:36 PM
fitmonkey1219's Avatar
Question wheel problem?? need your help!!
few days ago my driver side front wheel sounded like it was loose. everytime i hit a bump it rattles really bad. so i took it to a buddies house and we tightened the lug nuts thinking that was it...it wasn't. it's still making the sound. it sounds like having lug nuts completely off a rotor and it just bouncing around in side a hupcap (best way to describe the sound)...and this happens over every lil crack/bump in the road...please help!!
Old Sep 18, 2006 | 04:37 PM
im guessing ball joints or hub assyembly but i dunno, your truck should be twin I beam and i dont know alot about them yet.
-Patrick
Old Sep 18, 2006 | 04:40 PM
i forgot to add this is happening on my 2000 f150 i no longer have the 88..
Old Sep 18, 2006 | 04:43 PM
well update your profile, and i would say ball joints or hub assy again. How many miles are on it, and have you ever replaced those before on that truck?
Old Sep 18, 2006 | 04:45 PM
118k and no i havent replaced them before
Old Sep 18, 2006 | 04:58 PM
bbtheman's Avatar
It can be that your wheel bearing is going out. If you have slack in the bearing the rotor will clatter against the brake pads while driving and will stop making racket when the brakes are applied. I would jack up the tire and check the bearing.
Old Sep 18, 2006 | 05:02 PM
bearings = hub assybley b.c im pretty sure you have to replace the whole enchilada. Id check for play in the ball joints first. put the truck on jack stands with wheels off the ground, and grab tire top and bottom, and if there is more then a little play (movment) its time. like try to push inward on the top and pull out on the bottom. If that makes sense.
-Patrick
Old Sep 19, 2006 | 12:35 AM
ya that makes sense...although i had custom spindles made for my truck to lift it in the front and put 35's on it...can it still be replaced or will it be the spindle all together?
Old Sep 19, 2006 | 08:51 AM
Duffman0286's Avatar
sounds like bearings in the stearing knucle how much of lift is on ur truck some suspension lifts dont allow the suspension to hang like factory which cause alot of stress on axles
Old Sep 19, 2006 | 01:19 PM
bearings should be between the spindle and the rotor. i dont see how you put a new spindle on and not replace the ball joints. So im leaning towards bearings right now
Old Sep 19, 2006 | 04:06 PM
dptyscott's Avatar
Lift = trouble.
Old Sep 19, 2006 | 05:12 PM
its about a 6 or so in lift in the front...we used the original wheel bearings from the stock spindle...will post a pic of it when i get home...anyone have opinions on it having anything to do with the calipers?
