'97 master cylinder
Old Sep 1, 2006 | 08:21 PM
FF301's Avatar
I bought it at a local parts store $44.00 plus core charge (refunded when returned old one)
depending on how they stock it - you may have to swap some parts (as i did)
follow directions supplied- and bleed befor you install it then bleed the system again. I bled everything until i had new fluid at all tires
I also used synthetic oil
swapping out the cylinder was easy- disconnect any wires- (low fluid and speed control if equiped)
2 bolts hold the cylinder in place to the booster
when you are ready to install new cylinder i adjust the bolt coming out of the booster so it just touched the piston inside of the new cylinder (so as to have to apply a little pressure when sliding cylinder over mounting studs ) where it contacts the booster
there is a propper way of doing this in the service manual if you have access to one
hardest part was swapping the resovior - a big box wrench,rounded end so you don't put any holes in it - worked
while test drive was a little soft at first, after some short hard stops, pedel was good and i tested truck again today - still good
noticed fluid was down a little more so maybe there was a little priming needed to get rid any air in the top of the cylinder
i'm not driving the truck right now till i'm done with the heater core, so i can't say how things rely are until i get back on the road!!!!!!!!!!!!!
took abought 3 hours total time with my 4 yr olds help
reply if this helps - good luck
Old Sep 2, 2006 | 11:22 AM
jflex1's Avatar
Brake master cylinder
Hey thanks a bunch.. I will have to get a manual, but the ones I've seen cover not just the truck, but the suv also...does anyone know which is the best manual for our truck? I will be tackling this job this week mon or tues.. I will let you know how it comes out... about the oil what exactly did yo get ? I never seen brake fluid that was synthetic... ? ? ??
Old Sep 2, 2006 | 10:59 PM
FF301's Avatar
your local parts shop should have synth. oil
you will need a ford shop manual, haynes and chilton do not show the adjustment for the push pin.
Old Sep 3, 2006 | 01:41 AM
FF301's Avatar
I was just reading through some other forums - found one about the crouse control recall, ford will install a fuse harnes on the brake master cylinder speed control switch, but there is something about the switch leaking which couse's a short witch leads to the fire they are trying to stop, so you should install a new switch also, i will..................
