I need tires!
Old Aug 24, 2006 | 12:30 AM
pontiacman's Avatar
I need tires!
I have a 2004 F150 Reg Cab 4WD and 17" steel 7-lug wheels and its coming time that I need new tires. I would like to know the biggest size tires I can fit on this puppy with and without installing a leveling lift kit.
Old Aug 24, 2006 | 01:36 AM
drivestupid2004's Avatar
I'm in the same boat
I've got the same question,lol. I've got an 04 XLT supercab 4x2 and there isnt squat for OEM replacement tires. So i'm guessing I'll need to get a dif. tire size and i'd like to know what sizes would be a good replacement. Like you I dont want to lift/alter it but want the most aggressive i can fit under it and still have some room for suspension travel off road. I'd like to keep the 17" rims just to save some money too.
Old Aug 24, 2006 | 02:56 AM
hawg_man's Avatar
pontiacman go with 285/70/17 (33x11.50) they'll fit great, take a look at mine I know its a different model but itll give you an idea.
drivestupid - 265/70/17 (32x10.50) is the biggest you should go on a 2wd....
Old Aug 24, 2006 | 07:53 AM
wandell's Avatar
You can fit a 315/70-17's (35x12.50) with a leveling kit.
Old Aug 25, 2006 | 02:22 PM
pontiacman's Avatar
leveling kit
i saw a leveling kit in summit racing for $115 it was summit brand. is that fine to use or is there another one i can use? im trying to go as cheap as i can.
Old Aug 25, 2006 | 03:55 PM
wandell's Avatar
They all do the same thing.
Old Aug 26, 2006 | 03:03 AM
pontiacman's Avatar
i am planning on doing a 2.5" lift in the front. is a 35x12.5 going to fit on my factory stock 7 lug 17" rims? also what 35x12.5x17 tire do you recomend? im looking for a tire with good snow traction and some mud and i do a lot of highway driving so i dont want a noisy tire. thanks for your replies thus far
Old Aug 26, 2006 | 10:08 AM
wandell's Avatar
Yes, a 35x12.50 (315/70-17) will fit your OEM 7.5 inch wide wheels. I'd recommend the 315/70-17 BFG AT KO.
