ABS issues
Old Aug 15, 2006 | 08:27 AM
bone3349's Avatar
ABS issues
98 Ford Excab w/ 5.4
I purchased the vehicle 3 months ago and had to use the brakes hard on gravel. Noticed that there was no ABS, no vibration in the pedals, no sounds typical of abs, and a solid front skid with the front brakes.
so....... how can i tell if I have 4 wheel abs or just rear wheel abs?
Old Aug 15, 2006 | 09:07 AM
projectSHO89's Avatar
Inspect your front knuckes for the presence of the ABS sensors. If there are no wire harnesses anywhere on the front knuckles, you have RABS. If there are wire harnesses, you have 4WABS.
Does your ABS light come on for a couple of seconds when the vehicle is first started?
Steve
Old Aug 15, 2006 | 12:02 PM
bone3349's Avatar
ya it does, for a few seconds and then goes out
Old Aug 15, 2006 | 03:42 PM
This is the "normal" self-test.
I suspect you have RABS, in which case your observations are typical. Check for front ABS sensors to confirm which system is installed on your truck.
Steve
Old Aug 16, 2006 | 04:09 PM
theram's Avatar
Unhappy 1997 ford f-150 abs flashes 15 times
my light is flashing and can't tell what the problem is my brakes feel weird and when i turn it makes noise in the right from tire its a 4.2L standard trans and it started yeasterday
Old Sep 8, 2006 | 04:50 PM
HillsOttfam's Avatar
rear only ABS?
I put a set of aluminum (16x7 or whatever factory is) wheels on my '97 F-150, and now when I brake heavily on stops, the rear locks up--but usually only the rear pass. side. Any ideas?
