Tire PSI. Help?
Old Jul 18, 2006 | 04:02 PM
ROLLINGon38'S's Avatar
Tire PSI. Help?
I have a 97 Ex.cab F150. It has a 6in. Lift and a 3in. body lift..I have 38x15.5x16.5 super swamper TSL.... My truck handes really bad, every bump i bounce everywhere. I think most of that is because the frount shocks are blown out.... But what i want to know is how much air psi should i be running to get a good ride? And would changing the psi help me out??
Thanks.....
Old Jul 18, 2006 | 04:12 PM
wandell's Avatar
I would start around 40 psi. I wouldn't drop below 35psi.
Old Jul 18, 2006 | 04:17 PM
Alright, I think there is about 45 in them now....so I will try 40..... Also I have 12 sand bags full of rocks in the bed right by the tail gate, to try to get it to handel better....sould i add more or put them in a deffernt spot in my bed?? Thanks
Old Jul 19, 2006 | 07:31 PM
dukey_95ford's Avatar
i work at a tire shop on the average we only put 35psi in as big of a tire you have you could get by with 28 to 32
Old Jul 19, 2006 | 07:44 PM
06F250FX4's Avatar
i just put 33 12.5 on my truck and the tires came with a sticker on them that said inflate to 65 psi.
Old Jul 19, 2006 | 11:09 PM
lancem3's Avatar
I have 285/75/16 and what psi would you suggest for those?
Old Jul 20, 2006 | 06:57 AM
Johngs's Avatar
What kind of tires? Thats probably the max PSI, in which case 65 is way too high.
Old Jul 20, 2006 | 06:58 AM
Johngs's Avatar
If its just an LT, Load Range C or D tire, start at 45 PSI and adjust from there if needed.
