Correct rire pressure for 325/60r18???
Old Jul 15, 2006 | 05:30 PM
laxwarrior013's Avatar
I know that this question gets asked all the times but im running pro comp Xtreme all terrains size 325/60r18 and they are load rating E. I have a 4x4 2001 f-150 king ranch 5.4 v8. I think right now im running 40 psi...what is the correct psi i should be runnning????
Old Jul 15, 2006 | 05:46 PM
kingfish51's Avatar
When I had load range E tires, I ran them at 50 and got good tire wear.
Old Jul 15, 2006 | 06:11 PM
Frmboybuck's Avatar
Correct pressure is stamped on the sidewall of the tire
Old Jul 15, 2006 | 06:46 PM
kingfish51's Avatar
That is not the correct pressure to use. That is the max. In this case probably 80.
Old Jul 15, 2006 | 07:37 PM
Stamped on the side is max load 65 psi.....so you think i should up it to 50psi from my corrent 40?
Old Jul 15, 2006 | 08:21 PM
kingfish51's Avatar
Well with the load range E's I had they were a max of 80. That is was I was assuming was the max. Being the max on these are 65, I would run at around 45 and go from there. Max on load range D is 65 and that is what I use for those. I use 40 for my Load range C tires. I do think 40 is low for a load range E.
Old Jul 15, 2006 | 10:08 PM
thanks kingfish
thanks kingfish..anyone else with ideas/experience???
Old Jul 15, 2006 | 10:41 PM
zapster's Avatar
it should tell you what the psi. should be cold on the tire itself
check them in the AM before you go anywhere....
and adjust accordingly
...zap!
Old Jul 18, 2006 | 07:05 PM
Frmboybuck's Avatar
The correct pressure is stamped in the tire. In your case 65psi. That is the manufacturers recommendation. The max they refer to is the load carried by each tire, not the tire pressure.
Old Jul 19, 2006 | 12:28 AM
enormous's Avatar
I run my fronts at 47 and rear at 52 for the same size. Over 50 in the front make the ride harsher in my opinion.
Norm
