05 F150 Super Crew 4x4
hello I am looking at putting bigger tires on my truck. I just have a couple questiions. I know the tires are heavier but one thing I am not sure I understand is why larger tires make you loose MPG and or power. I mean saw the aftermarket tires are 50 lbs more per tire would the truck not run the same as say having an extra 2-300 lbs in th truck? Also this may be in the wrong forum but do you think a chip would negate the power and MPG loss of the bigger tires? Finally does anyone know if the Xcal II will allow you to change tire sizes or do you have to get the chip re-burned every time you change tire sizes? Thanks for any help.
