Whats this going to look like??? :(
so with 10 inch wide wheels...with 4.5 backspacing and 15.5 inch wide tires....how far out are my tires going to be? will this look bad???
Well, I think it's gonna stick out a lot. Like I said, just the new wheel will stick out 3 1/2 inches farther. But, I assume you are installing a suspension lift and most of those will widen your front track width making the wheels stick out even farther. I'd suggest looking at trucks with similar setups. Personally, I'd be looking for a wheel with more backspacing.
well wandell if you have the time and dont mind, could you help me find a 10 inch wide wheel with either 5.5 backspacing or 5 inch backspacing......thanks for the help
You guys are killing me with the pic's of the new F-150's like that it's bad enough every time I drive by the dealership I have to fight the urge to just pull in and take a look see, now I am seeing it on the puter
That rig looks Sweeeeeet
Originally Posted by theanimal
I disagree with it looking
To me it looks awesome and is the same exact look im going for on m truck. Here is a truck i found with basically the same setup you described.
theanimal, where did you find those pics at? were they from a member on here? i'm asking because i would like to know the specs on that truck. (tire size, rim size, lift size, etc.) i think it's perfect and would like to get mine something close to that this summer.
Got the pics from cardomain.com. I know that the guy has a fabtech 6" with an autospring 2" leveling kit. The rims are Moto metal 951 with -18 offset(4.75" backspacing) and the tires are Baja Claw 36/15.50/20
I really like this set up a lot
