Tire and wheel size confuzion
I know you guy's get this question all the time but I need some specific help. I have a 05 FX4 with a leveling kit on it and currently 18 in wheels. Was looking at 325x60/18 nitto at grapplers but have decided they are not aggressive enough. I guess my question is this...what size and brand should I go with if I stay with the 18's. Another question would be can I get 35x1250/17 under there without rubbing. I don't want a suspention or body lift because I barely fit into the garage as it is now. Would like to put 33x1250/18's but haven't found a good looking tire. Any help would be appreciated.
yes, with an aftermarket rim+ 35's you're going to have some issues- if you're only on roads, i figure you can do some trimming to relieve the problem- but if you take it off road, rubbing and bumps are going be a pain. (ie, if you want 35's or larger, lift the truck...)
