Stock Center Caps Will not Fit???
When I bought my truck it did not have the center caps for the 16" steel wheels. I bought a set of the center caps and the clips that hold them onto the lug nuts are too big. Do I need to get bigger lug nuts or is there a plastic part that goes over the lug nuts and then tha caps clip onto those?
Thanks.
Thanks.
Is this related to the infamous 12 mm or 14mm Lug Nut Question?
Also, I tried bending the clips in a little bit and they will fit this way but they are not really tight and I am thinking that they may come off while driving. There also is about a 1/8 inch gap between the wheel and the center cap when I put one on this way. These are Ford center caps too, not aftermarket ones.
Thanks for the help.
