Are there 17" LT's for '02 Screw?
Old Jan 21, 2006 | 04:49 PM
ssgar's Avatar
I tow a trailer with some sway on original P275/60R17's. Are there LT's available? Thanx
Old Jan 21, 2006 | 09:03 PM
ChrisT's Avatar
I have an 02 S-Cab Sport with the 17" rims and had the same size stock tires you have. I went with the BFG AT KO's LT285/70/17. Got some pics in my gallery but they were quite stuffed in the wheel wells with the stock 4X2 suspension.
Old Jan 21, 2006 | 10:45 PM
Johngs's Avatar
Yes you can get LT tires, what kind of tread are you looking for? Highway, all-terrain, mud tires???
Old Jan 22, 2006 | 01:37 AM
wetanner's Avatar
I replaced my BFG AT/KOs with bridgstone revos LT 265/70R 17s last fall. I have been verry happy with them so far.
Old Jan 22, 2006 | 08:58 AM
ZAXJAX's Avatar
Try discount tire direct, you should be able to find some there. I went with Nitto Terra Grappler A/T's and I love them. Much better than my Goodyear Wranglers
Old Jan 22, 2006 | 07:56 PM
rkjerue's Avatar
You won't find a LT tire in the stock size 275/60R17. Then closes size in an LT would be LT275/70R17 Goodyear AT/S, but I don't know if they will rub or not on a 2wd.
The 275/60R17 is about 30.0x11.00-17
The 275/70R17 is about 32.5x11.00-17
Old Jan 22, 2006 | 09:54 PM
ssgar's Avatar
Thanx for the replies.. A lot of LT labeled tires are for off road use with aggressive tread designs. I am looking more for on road use only, towing stability because of the LT tire wall stiffness. I think I'll research the Goodyears a little more.. Thanx again...
Old Jan 22, 2006 | 10:09 PM
Johngs's Avatar
If you are staying on road, get some Michelin's LTX M/S, they cost a little more, but you will get great tread life out of them.
Old Feb 20, 2006 | 03:09 PM
willsurf4food's Avatar
Hmmmm, I would tend to want to fix the root of the problem and tune the trailer setup.
I tow a two axel 5500lbs far and fast with no trouble on the stock tires..
Willsurf
Old Feb 21, 2006 | 06:52 AM
APT's Avatar
APT
You should not have problems from the stock tires as they are load rated well above your rear axle ratings. Are you using a WD hitch w/ sway control?
