Lug Nut Torque
Old 01-12-2006, 12:49 PM
DANSTER302's Avatar
Lug Nut Torque
this may be a old question but, i have not seen it :
what are the whell nut torque specs.?or, where can i find it ?
2000 F150 4x4
thanks
Old 01-12-2006, 04:55 PM
kingfish51's Avatar
If it is not stamped on the lug nut, a 14mm log is 150 ftlbs. A 12mm lug is 100 ftlbs. Ford changed somewhere are the 2000 model year. If you use a 21mm-13/16" socket for your lug nuts, it should be 14mm lugs.
Old 01-13-2006, 09:39 AM
DANSTER302's Avatar
thanks for the reply. i'll have to see what size the lugs are
Old 01-13-2006, 07:51 PM
BIGTY's Avatar
mine are 14 mm and i have an 03 but im pretty sure that my 97 only had 12s i run mine at 150lbs
Quick Reply: Lug Nut Torque
