need help on brakes!
ok well today i found out one of my back lines was sprayin, i checked it and found that i had very little fluid. i still had brakes i just had to push them to the floor, well i got it home and replaced the back line on it, i bled it and added fluid but i still have to push it to the floor, it made it only a little better
did i mess up the master cylender or something else major, and if i did how much am i looking to spend on a new one
what other brake system components may be messed up?
and is it ok to run it like this or will it damage something else too
did i mess up the master cylender or something else major, and if i did how much am i looking to spend on a new onewhat other brake system components may be messed up?
Originally Posted by 98Navi
Keep bleeding them. Chances are, you've got air somewhere in the middle.
ok thanks for the input
i guess ill drive it until i get a chance to bleed them, im gunna have to heat em up, iv been spraying the bleeders with penetrating oil for two days now so i might be able to break them loose with a little heat and luck, ill see
