305/75/16....any info?
Old 12-11-2005, 01:10 AM
Chapman's Avatar
I did a search and found little info about this tire size. I was dead set on 305/70/16, but after finding a tire in the 305/75, I think I want to go that route. My truck is an 03 4x4 Screw, no lift. Can I get this tire to fit on a 10" wheel without rubbing? Anyone have any pics? Any help would be great!
Old 12-11-2005, 02:23 AM
dodge_slayer01's Avatar
i dont think they will fit. a 305/70/16 is a 33x12.50 and with that tire you have to crank the t-bars up and trim some plastic. a 305/75/16 is a 34x12 it might because its not as wide, but i dont think it will without some type of lift. i say put a 3" bodylift and put some 35's. JMO
Old 12-11-2005, 10:19 AM
wandell's Avatar
Where did you see a 305/75-16? I've never seen that size. Could it have been a 315/75-16 (35x12.50)? To fit a 315/75-16 on a 16x10 inch wheel, you will have to install at least a 3 inch body lift. Even then you will have to crank up the torsion bars and trim the front bumper's lower plastic valance for clearance.
Old 12-11-2005, 01:16 PM
Chapman's Avatar
Here is the tire in question...I am planning on a 3"bl later on down the road, but if the 305/75's wont fit without it, I guess Ill have to go with the 305/70's.
http://www.stopandgotires.com/modelsize.asp?ProductCode='73235'
Old 12-11-2005, 02:15 PM
i say call stopandgotires. and ask them if thats right. i think that is a typo on their website. i know that mastercraft does make a 305/70/16 in that type of tire.
Old 12-14-2005, 11:27 PM
phillyford99's Avatar
THERE IS A WEB SITE ON EBAY THAT SELLS T.B. KEYS TO GIVE YOU 2.5IN OF LIFT SO THAT YOU CAN FIT UP TO A 35 W/OUT RUBBING. THIS KIT WILL SELL FOR ABOUT $85 WITH SHIPPING OR YOU CAN BUY THE TB KEYS AND REAR LEAFS FOR $170. I THINK THE WEB SITE IS UNLIMITED OFF ROAD.
Quick Reply: 305/75/16....any info?
