97 F150 4 by 4 trouble after ABS activation
was it ever bled dry? there is an abs valve that if it goes dry will flip and personally i would take it to a qualified mechanic to have them fix that if that is the problem. i dont mind working on brakes but abs is a differant ball game. have you have your brakes replaced or anything recently? #1 cause of sponginess is air in the lines. or maybe even your brake booster vac hose is cracked or not on all the way. after driving for a few min stop the truck and hold the brake down if it starts out at one level and starts going down father and farther you more then likely have a leak at the booster. could be hose or the booster itself.
compared to gm's and dodges brakes fords brakes are mushy. if you want to search there are a few posts on how to clean your slides and things on your brakes. fords are also know to get these parts dirty creating terrible feel. sorry i couldnt be more help for you. if it still seems its going farther then it should it might be time to visit the stealership
