Where to look?
Where to look?
Ok Guys, two ??
What size wheel looks best on a dark blue 03 screw 2X4, I think I would like to drop it in the later but just a little. going to just do the 2.5 shackles on the rear for now.
and does anyone know where you can order wheel blanks to make you own custom rims. I am a Moldmaker and have the ability to cut them anyway I want. Is this done very often?
How do you the offset and all? I will do the research before I start or just buy some and make them later.
What are you thoughts?
Allen
Allen
Go with 22's. I have an 2002 F150 Supercrew FX4 on 22's. I went with 305/45/22's for tires because it's a 4X4, but you can go with anything from 30 series on up. As for back spacing, be careful, my 22's are 9.5 inches wide with a 20 mm off set. I can get the first inch of my little finger between the tire and A-frame. So anything more than 22mm or so you might be into the A-frame. You can use the stock rims to get an estimate of what you have to work with. I know that a 22 inch rim with a 305/45/22 tire will fit a 2X4 according to Les Schwab and Discount tire. Hope this helped.
Rockafella
Gallery "rockafella"
2002 F150 Supercrew FX4 Rollin 22's
Rockafella
