ABS wire corrosion
Old Mar 10, 2005 | 11:32 AM
VMF214's Avatar
ABS wire corrosion
Can someone tell me where the wire or wire harness in question can be located. My ABS light is on and I have already replaced the rear diff. sensor. I would like to check out the possibility of a this wire corrosion issue. - Thanks
Old Mar 13, 2005 | 08:51 PM
supercrewbro's Avatar
corroded wire
you can check under the air filter tube . there should be your abs module. check for corrosion in/ on or around the wire plug. mine was the 4gauge red wire to that module. or you could just have a bad module
Old Mar 13, 2005 | 09:38 PM
VMF214's Avatar
Thanks, will check it in the morning...
Old Mar 19, 2005 | 10:15 PM
VMF214's Avatar
Well, I found the wire and sure enough it had a bulge about 1 inch from the ABS unit. Cut into it and got nothing out but green dust. I cleaned both ends back to good copper, tinned them and soldered them together. ABS light is now out (for now).
