tire size for 2001 supercrew
Old Sep 28, 2004 | 02:30 PM
jlgrizz's Avatar
I have a question on tire size.
What is the largest tire size I can run with the factory ride height and the factory 17" steel rims?? factory size 265/70/R17
Old Sep 28, 2004 | 05:15 PM
APT's Avatar
APT
Several are running 315/70R17 on stock suspension components. They did have to riae the torsion bar and tricm a piece of plastic from the fender, but it doesn't rub.
Old Sep 28, 2004 | 06:38 PM
wandell's Avatar
RIght, several people have fit 315/70-17's (35x12.50) by cranking up the torsion bars and using the stock 17x7.5 inch wheels.
Old Oct 1, 2004 | 07:08 AM
Jimmy C.'s Avatar
33 12.5 17 tires recommend a rim width larger than the 7.5 that comes stock. Can you in fact run a 33 12.5 17 on 7.5 w rim and not get wierd wear.
Old Oct 1, 2004 | 08:17 AM
wandell's Avatar
In theory, it will cause the center portion of the tire to wear slightly faster than the rest of the tire. Similar to running the tires at a high air pressure. You may or may not notice it over the life of the tire.
