BFG AT's....265's or 285's
Old Sep 15, 2004 | 02:56 PM
GapperT's Avatar
LT265 70R17's or LT285 70R17's? BFG AT's. What is the difference between the two? Planning to put some on a 2004 F150 XL 4x4 with a daystar 2.5 inch lift in the front.
Old Sep 15, 2004 | 04:00 PM
wandell's Avatar
A 265/70-17 is basically a 32x11.50-17 and a 285/70-17 is essentially a 33x11.50-17. Personally, I'd go with the 285's.
Old Sep 16, 2004 | 07:47 AM
GapperT's Avatar
That's kind of what I thought.....I figured they were a bit taller, but I was worried about the width.....I didn't want a really wide tire. Would both of these tires' widths be the same if they were mounted on a 17" rim?
Old Sep 16, 2004 | 08:07 AM
wandell's Avatar
I'm sorry. I just noticed my typo. A 265/70-17 is a 32x10.50. The first number is the width of the tire in millimeters. 265mm wide vs. 285mm wide.
Old Sep 16, 2004 | 09:52 AM
GapperT's Avatar
So basically the 285's are about 20 mm wider than the 265's....which is about the equivalent of an inch and a quarter or so. I think they have a better load rating too. Thanks
Old Sep 16, 2004 | 11:40 AM
APT's Avatar
APT
20mm ~ 0.8"
Divide by 25.4 mm per inch.
Old Sep 16, 2004 | 07:40 PM
GapperT's Avatar
Thanks, APT.......I've been leaning towards the 285's.....what would you recommend?
Old Sep 16, 2004 | 09:13 PM
Pickup Man's Avatar
I have a 97 Supercab Flareside Lariat, and I recommend the 285s.
They fill up the wheelwell good, and they perform well.
Old Sep 16, 2004 | 09:31 PM
F150Flare's Avatar
I've just recently purchased a set of 285/70/17 BFG tires and put them on the mickey thompson classic II. which is 17x9. I filled up the wells and blew them out on the side as well. definetly go with the 285s, the only drawback to these tire is the Price, mine were 185 a tire.
Old Sep 16, 2004 | 10:32 PM
APT's Avatar
APT
If you want the BFG AT KO, go for 285/70R17. I have them on my 03 and love how they look.
Old Sep 17, 2004 | 12:21 AM
Ghz's Avatar
Ghz
Question
APT & Pickup Man:
Did you notice a reduction in performance or mileage going from a 265-17 to a 285-17?
Old Sep 17, 2004 | 06:55 AM
APT's Avatar
APT
I have no exact comparison because the stock tires didn't make it through the first tank of gas. Based on my prior F-150 experience, I think these tires are negatively affecting performance and fuel economy. I won't be buying these tires again. I drive aggressively. Some may not notice the differences.
Old Sep 17, 2004 | 07:42 AM
Greeny's Avatar
Hey F150Flare,
I'm considering the same tire & wheel combo as you. Do you have any pics I can look at before investing so much money.
Greeny...
Old Oct 13, 2004 | 01:15 AM
lrhogfan's Avatar
APT, so are you saying that you would not buy the BFGoodrich again in the 285/70/17 size???
Old Oct 13, 2004 | 08:15 AM
APT's Avatar
APT
I won't buy the BFG AT KO in 285/70R17 again for this truck. I'll go back to 265/70 and probably Revos again. I'm sure most people wouldn't notice the effects on performance, though. Keep in mind, I do drive aggressively.
