33"s on 16x8
Old Jul 21, 2004 | 12:19 AM
silver00f's Avatar
33"s on 16x8
hey all,
im pretty sure this will fit, but i just wanted to confirm it. a 33" BFG m/t on a 16x8 w/4" of backspacing will fit on 2000 f-150 reg cab with no lift right? and will i have adjust the speedo at all?
thx all
--pete
Old Jul 21, 2004 | 08:14 AM
wandell's Avatar
Yes, they will fit, if the truck is a 4x4. You will have to fix the speedo if you want it to be accurate. How much it's off will depend on what your OEM tire size was. I went from a 30 inch tall tire to a 33 inch tire and mine if off approximately 5 MPH at 60.
Old Jul 25, 2004 | 11:59 PM
silver00f's Avatar
well,
its a 2wd so, am i gonna run into any problems? and i think the stock tires size is 235.
thx man
--pete
Old Jul 26, 2004 | 07:32 AM
wandell's Avatar
I have seen 285/75-16's (33x11.50) mounted on 16x8's on a stock 4x2, but it is a very tight fit. You will probably have to trim some plastic off the front bumper's lower valance. If you do not plan on ever lifting the truck, I would suggest a 265/75-16(32x10.50) on a 16x8 wheel.
Old Jul 27, 2004 | 01:26 AM
silver00f's Avatar
well,
i think the back will fit just fine. i am planning on a leveling kit (1.5"). but the 33"x12.50 will fit 16x8 rim, right? and also, what is the bolt pattern on the '00 f-150?
thx all
--pete
Old Jul 30, 2004 | 10:04 PM
silver00f's Avatar
so w. a leveling kit for a 00 2wd f-150 and 295/75 (33")on a 16x8 rim should fit, right?
thx all
--pete
Old Jul 31, 2004 | 12:01 AM
wandell's Avatar
I'd stick with a 285/75-16 (33x11.50) or a 305/70-16 (33x12.50) if I were you. A 295/75-16 is basically a 34x12.00-16.
Old Jul 31, 2004 | 02:03 AM
silver00f's Avatar
thx for the reply, but do you think w.the 305 i will have any problems turning or rubbing?
thx again
--pete
Old Jul 31, 2004 | 09:29 AM
wandell's Avatar
With 1.5 inches of lift, I think it would be close. If they rub, it will be on the front bumper's lower plastic valance, which is easily trimmed. 285's would probably be your best choice.
Old Aug 1, 2004 | 09:11 PM
silver00f's Avatar
i think ill go w.the 285's
thx man
--pete
