Front Rotors!!
Old Jun 12, 2004 | 03:38 PM
Doitmyself's Avatar
Front Rotors!!
I need help removing front rotors from F-150 4+4 .!996 model. How the heck does the darn thing come off??!! Took three screws off cover plate and can't seem to find anything holding cap on! Please reply soon ,work truck. Thanks.
Old Jun 13, 2004 | 03:29 PM
DIESELMAN's Avatar
FRONT ROTOR REMOVAL
YOU COULD HAVE 1 OF 2 TYPES OF FRONT BRAKE SETUPS,THE FIRST ONE IS A 2PIECE HUB AND ROTOR ON THIS ONE SET YOUR EMERGENCY BRAKE TAKE YOUR TIRES OFF,THEN TAKE YOUR CALIPERS OFF AND SET THE CALIPER OFF TO THE SIDE BUT DON`T LET IT HANG BY THE BRAKE HOSE GET A COAT HANGER OR SOMETHING TO HANG IT OFF YOUR FRAME OR SPRINGS,ONCE YOU GET THE CALIPER OFF YOU SHOULD BE ABLE TO SLIDE THE ROTOR OFF AND OVER THE HUB. IF YOU HAVE THE SECOND SETUP YOUR LOOKING AT TAKING THE HUBS OFF-IT`S NOT THAT BIG OF A JOB UNLESS YOU`VE NEVER DONE IT BEFORE,GO GET A HAYNES MANUAL IT`LL BE A BIG HELP. HOPE THAT HELPS SOMEWHAT
Old Jun 15, 2004 | 05:46 PM
Doitmyself's Avatar
Rotors
Thanks for the reply. I'll check it out and get back to ya.
