how can i get 285/70/16's on til lift
more than likely i'll be getting a lift in the next month or so (at least a 3" body lift) but i'm looking at getting some new tires now. is there any way i can temporarily fit 285/70/16's on my 2wd truck til the lift? would coil spacers in the front take care of the rub until i can get the lift. if i have a little rub i can use it as an excuse (to my wife) to get the lift sooner (always thinkin ). any suggestions are appreciated (trimming, anything). thanks
i was just going on looks and the little knowledge i have about lifts. looks like a stock 4X4 is about 2-4" higher than my 2wd, also i've heard that the only difference between the 4X4's and the 2wd is the lift block in the back (but i'm sure there's a longer coil or something in the front too). hope that helps. still want my 285's and i'm really going to start putting it on the wife for a lift...wish me luck
i put coil spacers in the front and trimed the plastic valance on the front bumper and can fit 285's with no rbbing.
good luck and just do the spacers with a lift coil instead of the body. i am about to buy the coils, mabey, and then i will have the front sitting slightly higher than the rear.
