abs light on after brake job
More than likey you had your master cylinder top off prior to changing the pads and once the pads were changed the level of brake fluid inside the master cylinder is to high and this will cause your ABS on newer models and your E-Brake light on older models to stay on steady. So check the level in you master cylinder and make sure it is not over filled. Also if you changed your rotors you may have disconnect your wire to your ABS sensor which reads off the ring gear on the back of the rotor, if this is the case the ABS sensor will always read as OPEN and this will also cause your light to stay steady on.
