tire size on ORP 17 inchers
I'm looking to put some BFG Baja T/A's on my '00 w/ ORP, and the smallest that these are made for the ORP 17's is 35x12.5R17LT/C... have any of you put 35" tires on w/o a lift? eventually I plan on doing a 4 or 6-inch lift, but I really want to change out those POS goodyears that came with the truck sometime soon.
on
1 Post
I wouldnt try it, unless you can cut the hell out of your fenders to fit the 35's. I have 35's right now with a 3" body lift, and when the wheels are fully locked, there might be maybe 3/4" between my tire and the rear part of the wheel well.
Black 1997 F-150 Extended Cab
4x4 w/Off-Road Package
5.4 liter Triton V8
Luverne Stainless Steel Nerf Bars
DeeZee Silver Series Toolbox
Grizzly Oval Style Chrome Grill/Brush Guard
Wrap around bug shield
Ventshade Ventvisors
Ford Factory Bedliner
Pioneer Deh-P6000 45 Watt CD Stereo
3" Trailmaster Body Lift
Smittybilt Outland Tail Light guards.
16x10 American Racing Polished Atlas Wheels
4 315/75R16 BF Goodrich All-Terrain TA/KO Tires on all four corners.
Flowmaster 50 Muffler w/Dual Pipes & 2 18" Stainless Tips
MTX 2 Channel Amp w/Crossover
2 MTX 10" Subwoofers w/Box
Next Up: 4" Rancho Suspension Lift
5.4 liter Triton V8
I'm not even sure if you can stuff a 35" tire into the wheelwell without a lift. If you can it will rub SUPER bad when you try and turn. Minimum you would have to do is put a 3" body lift in. You can pick one up for about $130.
1997 F-150 Lariat
Ext Cab Short Box
4x4 Off Road Package
3.55 Gears
285/75 R16 Kelly Springfield Trailcutter RTs
My 2 cents worth
If you're gonna stroke it, POWERSTROKE IT!!!
http://www.powerstroke73.homestead.com/
1997 F-150 Lariat
Ext Cab Short Box
3.55 Gears
My 2 cents worth
JupiterAK has the procomp 35x12.5x17 on 16x8 AR rims. Ask him. His is a 250 LD so it may be up higher to start with and I think he may have a lift as well... but ask anyhow.
2001.5 SuperCrew XLT 4X4 (Gen III)
Silver Clearcoat Metallic
Deep Wedgewood Blue (accent)
5.4L V8
Chrome Tubular Step Bars (Ford)
Captains Chairs
Power Moonroof
3.55 LS
6750 GVWR
Class III Towing Pkg
Mods:
Harley Davidson Exhaust
'01 Lightning Head/Tail Lamps
Pioneer DEH-9200r
Boston Acoustic Components & 5X7s
Box Liner (Ford)
Splashguards (Ford)
Bug Defector Doubles as Rock and Sand/Salt Deflector in these snowy Canadian winters
K&N Air Filter
To Come:
17" Rims/Tires w/ BFG A/T or ProComps
WMS Velocity Tube
Radio Delay Mod
Eurolights
5.4L V8
Captains Chairs
Power Moonroof
3.55 LS
6750 GVWR
Mods:
Pioneer DEH-9200r
Box Liner (Ford)
Splashguards (Ford)
K&N Air Filter
To Come:
WMS Velocity Tube
Radio Delay Mod
Eurolights
I've seen 35's on a non-lifted SuperCrew BUT he had the t-bars cranked up 1 1/2" and cut a fair amount of plastic off in front of the fender and said it still rubs. It looked ok but not sure how it worked. I wouldn't do it to mine but that's just me.
2001 F-150 SuperCrew Lariat 4x4
2000 Suburban LT 4x4
2000 Honda RC51
1999 Mustang GT Convertible
2000 Honda RC51
Wow, I'm excited. I didn't know BFG made a 35" tire for a 17" rim. Although when I priced them at summitracing.com they came to $499 a piece. What are the prices you have seen? I don't think you can get a 35" tire on w/o a lift. You can if you had a 3" body lift. Several people here have that combo. I am most likely going to be using the 3" body lift and Procomp MT 33/12.5/17 on the factory ORP rims unless someone knows where to get these BFGs for cheap. BTW, I thought JupiterAK had the procomp MT 33/12.5/17 on his f250LD? The 33" tires will fit without a lift.
kev
kev
