Max Tire Size
Old Mar 17, 2004 | 05:53 PM
DNT1997's Avatar
Max Tire Size
I have a 1997 F150 2x4 and would like to put on some bigger rims/tires. I don't have the owner manual anymore so I don't know what the rim size that's on now. I know I got the factory 17's but don't know the width. What's the max tire size I can go with on those. Also I've thought about going to 18 or 19x8 rim. Will soemthing like that work? What's the biggest tire I can put on that type of rim?
Old Mar 18, 2004 | 08:28 AM
wandell's Avatar
Your stock rims are 17x7.5 inches. What type of tire do you want? Street or off road? If you want an off road tire, you can easily fit a 265/70-17 (32x10.50) or even squeeze a 285/70-17 (33x11.50) on your truck.
Old Mar 18, 2004 | 11:42 AM
DNT1997's Avatar
Thanksd for the response. I won't be doing any off-roading, it's a standard set-up. I was thinking about something like a Goodyear Eagle. I have 285's on now but would like to go to a wider set-up maybe an 8" or 9". I don't know that I want to go as big as a 20" rim and lower profile tires. I'd like to fill the well as much as possible with decent split of rim and tire.
