Wheel Adapters
Old Mar 11, 2004 | 09:20 PM
Marlon_E's Avatar
Wheel Adapters
Hi
Just Wondering if u Guys Know aBout The wheel adapters i Own a 90s ford truck and i want to change the Bolt pattern to the 5x135 0r the 6x 135
are There any risks or something
Old Mar 11, 2004 | 11:27 PM
powerstroke73's Avatar
Accelerated wear on front wheel bearings, all steering components, brakes, ball joints, etc. What it does is create a leverage on the bearings that wasn't ever intended to be there. I would never recommend running them. They will also create a weak link there which can cause failure. If you ever load anything in your bed or you tow you will run a much higher risk of breakage of the spacers. Do yourself and everyone on the road a favor and skip the spacers/adapters.
Old Mar 12, 2004 | 12:55 PM
Marlon_E's Avatar
Ok Thanks For The Info
