305/70/16 fit on stock wheels??
Old May 12, 2001 | 10:53 AM
crazedf1's Avatar
Question 305/70/16 fit on stock wheels??
will 305/70/16 fit on the stock wheels. thanks for any help
2000 4.2l V-6 w/sport package std. cab. 2wd, bright red
billet grille
clear corners
herculiner bed liner
k&n filter
sony head unit
two 10" kicker comps.
sony amp
viper alarm
future: (being in college cuts most of the funds)
spindle lift
fipk
chip
headers
exhaust
Old May 12, 2001 | 11:58 PM
Shifter's Avatar
Post
I saw a demo in a local dealer's showroom (Stirling Ford) about two years ago when I had my '98. It was a 4X4 SuperCab, and it had 305-70s on stock rims. Sidewalls looked pretty compressed and bent in, but the truck sure looked tough.
Black 2000 SC short-box XLT. 4.2 V-6, 5-speed, 3.55 limited-slip. CD, remote entry, factory side steps, FORD box liner, rear fender inner splash shields (TSB 00-09-05).
My third F-series ordered new. The other two: '73 F-100 Custom, 240 cube 6, 3 on the tree, tan, "West Coast" mirrors, step bumper, knitted vinyl seat, AM radio; and '98 F-150 SC short-box XL, XLS package, Pacific Green, 4.2 5-speed, 3.55 LS, FM-cassette.
GREAT trucks!
Old May 13, 2001 | 01:54 PM
crazedf1's Avatar
Post
thanks alot
Old May 14, 2001 | 02:13 AM
KYFordFreak's Avatar
Post
Yes a 305/70/16 should fit on the stock rim, but you will have some sidewall bulge and will need to crank up the torsion bars. For comparison's a 305/70/16 is 32.8 tall and 12 inches wide as where a 285/75/16 is 32.8 tall and only 11.2 wide. Now if you look at some of the posts on here or ask around you will see that a lot of the people in here have 285's. The 285 is just slightly skinner which will make for less sidewall bulge. I don't think .8 inches is going to make that much of a difference, IMO.
97 Ford F150 XLT 4wd 4.6L auto, Std cab/Long bed, PW,PL, and PM, captian chairs w/arm rests
Sylvania Cool Blue Bulbs, Ford logo hitch and license plate, tinted windows, blackouts front and rear(w/ford logos on front blackouts),ventvisors all around, painted logos on door sills and under hood, 55w backup lights, K&N Filter, custom 4x4 emblems,and much more to come
thomaswright5714@hotmail.com
Old May 14, 2001 | 10:26 AM
bambino's Avatar
Post
I've seen a few trucks with 305 GY AT/S on the same rims that KYFordFreak has - they do look neat, but the middle channel of tread, for those who know the tire - was noticeably worn.
If I had the 16" rims, I'd be putting on 285 MT's. 305's look nice for a while, but the 285 looks good and fits good.
Bambino
Bambino Worldwide
Owners Gallery Truck #179
1999 reg cab/short box/ORP/Silver on Dk Graphite - 3.55; 4.6l 5sp; Factory Tonneau; Kicker amp'd sub tubes; Rockford Fosgate components up front; Custom Exhaust; Mobil 1 5w30/Motorcraft FL820s; Amsoil Series 2k in the driveline.
Old May 14, 2001 | 11:41 AM
Spargo2's Avatar
Cool
Well I just put on 33-12.50-17 Pro-Comp AT's on mine and they fit great!!!
KYFord, sorry I havent had a chance to e-mail you yet, I'll try later.
For more info go to http://www.f150world.com/Spargo2/
My 2000 F-150
It's A KC Thing....You Wouldn't Understand!!!
[This message has been edited by Spargo2 (edited 05-14-2001).]
Old May 14, 2001 | 11:46 AM
KSinLA's Avatar
Post
Check the tire manufacturer's recommendation for the specific tire. Going beyone those recommendations creates safety problems and may void the tire warranty.
Old May 14, 2001 | 01:39 PM
crazedf1's Avatar
Post
is there a difference between 285/70/16 and 285/75/16. i have no idea im new to this whole metric sizing. the last time i got bigger tires they were all in inches. well, any help would help. thanks
billet grille
clear corners
k&n filter
sony head unit
sony amp
viper alarm
spindle lift
fipk
chip
headers
exhaust
Old May 14, 2001 | 01:47 PM
FrankP's Avatar
Post
All tires have a "range" of rim widths that is allowable, with a specific width which is preferable. That said, the preferable width is the one to use. If you run them on either side of this, you will not get the optimal distance for tread wear. Especially if you run rims on the narrow side of 'prefered'.
If you choose a tire and run it on a .5" narrower than its 'prefered' size, you can away with it - barely.
As Bambino points out "305 GY AT/S ... they do look neat, but the middle channel of tread, for those who know the tire - was noticeably worn."
My sotck rims are only 7" wide. So I'll not go beyond 265/75 unless I buy new rims. That's my .5" 'beyond prefered'.
Frank
Old May 14, 2001 | 08:03 PM
crazedf1's Avatar
Post
well mine are 16x7 so 285/70 or 75/16 are not good? i have no idea. thanks
Old May 15, 2001 | 03:04 AM
Post
I am not sure if your truck came stock with 255/70/16's ( check the door sticker) but this is what I based my results on. The diff between 285/70/16 and 285/75/16 is that the 70 series will have a sidewall of about 7.85 inches, diameter of 31.71 and the 75 series will have sidewall of about 8.42, diameter of 32.8, both are about the same width ( 305/70/16's have the same width and diameter of the 285/75 but are 12 inches wide). Point being that your best bet is to go with no bigger than a 285/75, you will get a little more clearance and it will fill up the fender and another plus is that you can find more 285/75's. Your speedometer will be off by 8.45%, rear axle would be like going to a 3.25 rear axle and rpm ( based at 2200 rpm) would drop to 2014.
I get all my info from this tire calculator, just click compare tire A to tire B.
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Old May 15, 2001 | 10:05 AM
crazedf1's Avatar
Post
thanks alot i belive im going to go with 285/75/16 unless someone else sees it from another angle, that might perswade me back to 305
billet grille
clear corners
k&n filter
sony head unit
sony amp
viper alarm
spindle lift
fipk
chip
headers
exhaust
Old May 16, 2001 | 03:14 PM
crazedf1's Avatar
Post
i had pathfindr atr a/s on my last truck, but i sold it a month or two after i got the tires. well i was wondering if anyone has had them for longer than two months, and if so what did you think about them. and if anyone else can tell me what they think about them. thanks
Old May 16, 2001 | 05:01 PM
mudder's Avatar
Post
I Have 285's on my truck, and will be switching to 305 Pro Comps soon. The 285's are just to skinny for a lifted 4x4.
98 Black F150 S/C 4x4 ORP 5.4
4" Rancho lift, 14 KC lights, lots of other goodies. Check out www.F150World.com/Mudder for pics and all the info.
Old May 17, 2001 | 02:22 AM
Post
Mudder
Love the truck. If you have a 4in lift why not go bigger than 305/70's, I'd say get at least a 315/75's. Just my .02 cents, It's your truck I wouldn't want people to tell me what to do either.
97 Ford F150 XLT 4x4 4.6L auto, Std cab/Long bed, 3.55LS rear axle, PW,PL, and PM, captian chairs w/arm rests
