Will wider wheels help?
Just upgraded my OEM 255-75-16s to a set of 275-70-16 Michelins. Nice tires, but I was hoping for a wider stance look. Question: If I now went back and got some 16 x 10'' wheels and had these new Michelins mounted, would they be look wider and lower on the wider rims? If not, what is a commonwide tire size or a 16" wheel?
oh yes that'd do it. But i'm not too confident if you can even fit that tire on a 16x10 rim. You may want to just look for a 16x8 wheel with an offset (ex. Eagle 058 or American Racing Baja or American Racing Atlas). Positive offset is a no no if you want more width to the tires. An offset of 0 is better than factory. Tire height will decrease about a 1/4" with wider rims. Personally i'd look into the 16x8 Eagle 058(aka Eagle 589's) they are good lookin to me and with the negative offset they will set off ur ride by adding that width to the tire. Hope this helps.
-Brandon Warford
97 F150 4x4 Sport Brt. Red SuperCab
4.6l Triton V8
3.55LS
3" Performance Acc. Body Lift & lift lips
1-1.5" torsion bar adjust. so it sits level
Clear Corner Lenses
315/75R16 Yoko. Geolander MTs
American Racing Atlas 16x10
Pioneer 8000 3D series
Boston Acoustic 5x7s
Sony Xplode 4ch Amp
(2) 8" RF XLC Subs
True Dual Exhaust
--(2) Stage 3 Flows (Exits like the Lightning)
Custom 4x4 Sticker
Viper Alarm
FUTURE MODS:
4.56 gears
Repaint around Headlights where clearcoat is coming off >=(
Possibly a Manik Brush Guard and Roll Bar--we'll see
Thats about it for now!
Killintime4fun@aol.com
"THROUGH the river and OVER the woods to grandmother's house we go."
"...the road curves to the right and there are a lot of signs that say you cannot turn left...TURN LEFT."
-Brandon Warford
4.6l Triton V8
3.55LS
Clear Corner Lenses
Sony Xplode 4ch Amp
(2) 8" RF XLC Subs
True Dual Exhaust
Custom 4x4 Sticker
Viper Alarm
FUTURE MODS:
4.56 gears
that is correct. The more negative the offset it means the "deeper" the wheel is. If a wheel has a positive offset than the wheel is pretty shallow. Factory rims are all positive (by how much i'm not sure). Some wheels come with an offset of 0 which is deeper than stock and i think looks good, but if you want your tires to stick out you want a negative. My atlas' in the pics below are like -26mm offset. Baja's/589's are the same in a 10" wide wheel. I'm not sure what offset is on an 8" wheel but anything 0 or over will increase tire width. Especially since you are also increasing wheel width an inch from stock 7" width to 8"...Hope this helps
-Brandon Warford
4.6l Triton V8
3.55LS
Clear Corner Lenses
Sony Xplode 4ch Amp
(2) 8" RF XLC Subs
True Dual Exhaust
Custom 4x4 Sticker
Viper Alarm
FUTURE MODS:
4.56 gears
-Brandon Warford
4.6l Triton V8
3.55LS
Clear Corner Lenses
Sony Xplode 4ch Amp
(2) 8" RF XLC Subs
True Dual Exhaust
Custom 4x4 Sticker
Viper Alarm
FUTURE MODS:
4.56 gears
