Wheels interchangeable?
I've got a 2000 F-150 and am replacing the wheels and tires that came from the factory. I want to give the wheels and tires off my 2000 to my dad to put on his '95 F-150. Do you guys know if they'll fit his truck? The wheels are 16's and the tires are 235/70/R16's.
BigDawg
2000 F-150 SuperCab
Oxford White/Harvest Gold
5.4L V8
3.31 Gear
Husky Liners
Ford Duraliner
FlowMaster 40 Series
K&N FilterCharger
Airaid FIPK
BigDawg
2000 F-150 SuperCab
5.4L V8
3.31 Gear
Husky Liners
Ford Duraliner
K&N FilterCharger
Airaid FIPK
Well I understand that the 97's and up are the same, but are the 95's really different? If so, what is the lug pattern on them?
BigDawg
2000 F-150 SuperCab
5.4L V8
3.31 Gear
Husky Liners
Ford Duraliner
K&N FilterCharger
Airaid FIPK
BigDawg
2000 F-150 SuperCab
5.4L V8
3.31 Gear
Husky Liners
Ford Duraliner
K&N FilterCharger
Airaid FIPK
The '97-up uses a 5-bolt pattern in a 135mm (5.31") circle. I think the older F150s use 5-bolts in a 5.5" pattern.
For '00, Ford increased the lug-bolt diameter to 14mm. So even rims from a '97-'99 won't fit on a '00. (Been there, tried that.) Also, the new rims are hub-centric (vs lug-centric) and require the type of lugnuts you have on the '00. The old 1/2" acorn-style nuts that came on the '95 wont work right with the new rims and the new truck's lug-nuts won't work with the old rims.
If you must really know, you could always pull one off each truck and try it.
1997 4x4 Expedition- 4.6L, true dual exhaust w/glass-packs, K&N air filter, SuperChip, airbox mods, Edelbrock shocks, 285/75R16 BFG ATs, 2000 "XLT" wheels, 4.10 gears, Auburn LS, Clarion In-dash CD player, Smitty Bilt push bars and nerf bars.
2000 4x2 F150 XLT Reg. Cab LWB- 5.4L, Tow Pkg, 3.55LS, CD player,Remote Keyless Entry, Sliding back glass, Special Appearance Pkg., tinted windows, Line-X bedliner, K&N air filter, SuperChip, airbox mods, 285/60R16 Goodyear Eagle GT IIs and Prime #155 wheels.
http://members.visualcities.com/NoMo
[This message has been edited by nomo (edited 09-09-2000).]
Location: Houston, by way of every major city in America.
on
While we're on the subject,are the new style chrome 17"rims on the 150 and Expy a 99 or 2000? I've wanted a set since the first time I saw them. I am asking about those sharp,aluminum ones,not the steelies. Thanks for any help
,,,,,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
Hoping for deliverance from door crack hell.
,,,,,,,98
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
on
,,,,,,,98
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
,,,,,,,98
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
