adjustable pedals...?
Wasn't sure where to post this... hope it gets seen...
Has anyone out there added adjustable pedals? I did some searching, but couldn't find anything. That doesn't mean I didn't overlook something though...
thanks...
thanks...
I am sure it can be done. Try a search on one of the frod dealers parts websites ( some are referenced in threads) and see what parts they might have. I know that the mounting points are probably present if the option was available for your model and year.
Well, I have looked at a set not on a truck, and compared that to my truck. It appears they'll just bolt right in. The only thing would be wiring up the switch, which the guy doesn't have...
Plus it looks like I could then add a set of Harley pedals, since the stock non-adjustable gas pedal is not removeable...
Sounds cool, I have them on my '03 and it is great. I drive several hundred miles a day and it helps to be able to move both the seat and the pedals around so as not to get cramped up. FYI the switch used for the pedals is a generic one. The same style switch also operates the power rear window on mine.
I have the adjustable pedals on my truck. I only got them since I figured that my wife wouldn't have to move the seat so far up, but she does anyway. I can't remember the last time I actually adjusted them. Good luck with your install bro!
-Brian
-Brian
