Vibration during braking
Old Oct 21, 2003 | 10:58 AM
97WhiteLariat's Avatar
Ok, new shocks all the way around, new tires all the way around, and new drums and shoes on the rear. I have an up and down vibration or almost a shudder when braking thru 35-40 MPH that seems to start in the rear of my truck. It goes away once I get below 35 MPH. I had the problem before all the new items were changed out and none of them have changed the problem. It's a 97 Supercab 4X4 with stock sized tires and stock wheels. Any ideas???
Old Oct 21, 2003 | 02:01 PM
tkarter's Avatar
Check the drive shaft.
Old Oct 21, 2003 | 02:22 PM
Check the driveshaft for vibes under braking? It vibes no other time than braking and at that speed. If I let it coast thru that speed it doesn't vibrate.
Old Oct 21, 2003 | 08:12 PM
sdiesel316's Avatar
Make sure the new set of tires are balanced properly.
Old Oct 21, 2003 | 08:42 PM
I really don't think that's the problem...The main reason I changed the tires was to eliminate the vibe; along with the new brakes and shocks...nothing seems to fix it. BTW, the new tires were balanced to 45MPH...
Old Oct 21, 2003 | 11:46 PM
poolvibe's Avatar
Sounds like warped front rotors to me. make sure you torque your front lug nuts to proper specs (I believe 150 ft #s). Have your front rotors checked for runout.
Can you feel it in the pedal at all?
Frank
Old Oct 22, 2003 | 07:35 AM
I had to take it out for a drive to check. Yeah I can feel it a little bit in the pedal. It doesn't like that strong of a vibe in the pedal to do what I'm feeling in the back of the truck though. It shakes so much , you can actually see the headlight beams shaking. I'l have the front checked out though and report back.
Old Oct 22, 2003 | 12:52 PM
Changed out the front rotors and pads and the vibe is gone. Sure felt like it was coming from the rear though, Thanks
