abs fuse blowin
Old Oct 5, 2003 | 08:45 PM
desertrat3's Avatar
Question abs fuse blowin
Each time I hit the brakes my abs fuse blows. Last time I took my truck out I laid it up on the left side. once we got it back on all fours the abs fuse blows out which in turn you can not pull it out of park, and the break lites don't work. What should I check? Break fluid ok, bulbs ok, I did remove the plug from the break switch, hook up ohm meter it shows -12.43 also a bref contenuity when connected. if I short the two wires out it blows the fuse. what next???
Old Oct 7, 2003 | 08:37 PM
desertrat3's Avatar
Re: abs fuse blowin
I forgot I have a 94 extended cab F250 monster 40 inch tires with a 12 inch lift...
Old Oct 8, 2003 | 01:09 AM
Pestco1's Avatar
Is there damage to the left front fender? You could have pinched the wiring for the ABS where it meets the components under the master cyl. If the brake lights don't work you could also be shorting the brake light voltage some where to the ABS circuit.
Old Oct 9, 2003 | 12:21 AM
desertrat3's Avatar
yes the left front fender is smashed, I did not think it was that bad but I will have to check tomorrow if any wires are smashed.
Thanks I let you know...
