front rotors
Old Sep 7, 2003 | 08:24 PM
mgmeyer's Avatar
front rotors
Looking for some help. I need to remove my front rotors but they seem to be rust welded on. I "ve sprayed them with pen oil but still no luck. Any suggestions.
Old Sep 8, 2003 | 03:10 PM
mikemike98's Avatar
disk remove
What kind of truck? some don,t separate.
If you can ,just remove the whole hub with the disk.
Remove the bearings and grease, heat it up with a torch or us a press or puller +hammer to separate. Some disks and drums have a jacking hole; it'a threaded hole you just thread a bolt into to separate the two parts.
If you've been hammering on it hard, you may want to check you bearings for dammage.
Old Sep 9, 2003 | 08:26 PM
Harold's Avatar
That is the same problem I am having. 1998 f250 - 7 lug 4x4. I can't get the front rotors off to save my life. I bought the new rotors and they look as though they should slip right off/on once the caliper mount is removed. Even removed the 35mm nut and found that got me no where. I have a large gear puller I was going to try next. The hammer trick didn't touch them. Hate to put heat to it but will if necessary... HELP!
H
Old Sep 10, 2003 | 12:53 AM
FlaresideGuy's Avatar
I was fortunate that the hammer trick and WD40 did it, but I was taking the rear drums off my 96 Aerostar and was introduced to PB Blaster - best stuff since sliced bread. It took a few hours to let is soak in and then another treatment, but the drum broke loose.
I would try the PB Blaster on it - squirt it around where the lug nuts are and get it behind the rotor - spin the rotor around so that the stuff drains in to the center of the hub.
Hope this helps!
John
Old Sep 10, 2003 | 12:40 PM
Harold's Avatar
Thanks John. I am going to try the PB with a larger puller. Hopefully it works!
H
